?? after rear axle check. Updated with pics
Hello! Well let's begin, that after 2 years and 45 000 miles of driving my truck i start paying attention to PM
. Last wheek i rebuilded front axle,and now it's time for rear. Today i removed rear abs sensors to clean them (since i was having issues with activating abs at low speeds), and discovered that my driver side abs sensor's tip was bent, and that plastic cap that should be on top of that tip is missing. Also both of the rear wheels have a litlle play in them. So, my questions, after reading all the treads about damaged rear spindels, are: is it garanteed that my spindle is worn out? and also what could cause the damage to that abs sensor? Just hopping for the best ,and preparing for the worst
Thank You!
Thank You!
In the end i did it just about like you sad. Tighten to 43 ft-lbf, turn it several times,tighten to 43 again. Then losen it until it can be turn by hand,then tighten it as hard as i can, by hand. And then gave it about 1/4 of the turn. Readings on the fishscale were 6-10 lbs. (the fronts were much easier). Went on the highway for about 20 miles. After that the hubs were warm,nothing like hot(cuold easy keep my hand on them). So i guess i'm fine for now. Will check for 6-12 o'clock wheel play in couple of days.
