- Thread starter
- #21
I installed the oem from shackles and sent An email to Ironman.
Well. It rides great actually but only after I installed a 4° shim to the back. I feel either the front or the rear springs are wrong. I like the rear height but like you see the shackle is not the right angle.
move your rear shackle perches in about an inch.... the leafs could be a solid inch longer and issue would go away but have seen this be an issue with the hell for stout lifts and shackles. moving the shackle hangers in an inch resolves the problem... i do it on the front and the rear for hell for stout lifts
Ok so you do have Ironman springs. Your front looks exactly like mine did, and the shackle angle is the same too. I talked to Chris Miller at Ironman and he sent out new fronts, I did go with the heavies up front the second time.
Chris Miller <miller@ironman4x4america.com>
took a fair amount of work to get him to sit level.... typically i go with whoevers heavy rear springs and HFS shackles and move the perches.... everyones springs seem to be a little short and all seem to cause bad angles once you hit the 2 inch mark and add the hell for stout shacklesThe only reason I bought longer shackles was to see if I could get it to sit a bit more level but even with longer shackles it still has a lot of rake.
I plan on selling the landcruiser once all this is sorted. I just don’t wanna modify too much or hack anything up.
It’s their 2” performance lift kit. I took the hfs front shackles off today and put the stock ones onto take the pics so they can see how much of a rake it has. I called them today and sent the pics. Hope to hear back soon.
Well. They told me to just drive it. “It will settle after 5000 miles”
this is so annoying
WTF...hopefully you sent that photo to those numbnuts. That kind of sh*t really pisses me off. C’mon Chris!!
Oh and that looks like the original factory spare tire under there, wonder if it has ever been dropped, cool artifact.
Did you take before and after measurements from center of hub to wheel well? Post those numbers up if you did. On mine I got 3" lift in the back and 0-1" on the front. I had measurements and pictures when I talked to them. Their front springs gave almost no lift which is not what I ordered so they're obligated to send correct springs. Measurements are important.
Man I’ll never buy Ironman stuff again. The front I had to use a longer shackle to try to make it sit level. But I could only go so long on a shackle. I called and talked to some guy named “bubba”. No help.Bumping this thread as I just installed an iron Man medium weight lift on my friend's 62 and we are having all the problems described above.
Rear springs were so short we could barely get the shackles in. I actually had to put a load on the spring to lengthen it to make the shackle reach. So of course the rear shackles are at a horrible angle and inverting all the time.
Also the fronts springs Don't appear to have raised it 2" in my estimation.
Unfortunately we had it jacked up to do knuckles and a whole bunch of other work long before the lift went on so I don't have before after measurements, which I always do before putting on a lift.
Not happy at all with this product.
My friend is calling iron Man to try to get it sorted. we'll see.
They expect everyone to load the s*** out of it to make it work. Guess what?!not everyone goes camping everyday and loads the crap out of their rig.
