African Outback Loadbars question
Oregon
Website
www.brian894x4.com
I'm looking for the lowest profile gutter mount load bars/ cross bars I can find. I'm very limited in hieght with my garage. Just looking for something that I can easily install and remove a roofrack onto, but maybe leave the cross bars on all the time.
I think the African Outback Loadbars from Slee will do the trick, but does anyone know how low profile they are? How much height they are from the top of the roof to the top of the load bar?
Any other recommendations? My '95 FZJ80 never came with a factory roof rack.
Thanks for the info.
I haven't bought any yet. Still debating on load bars and my own custom roofrack or just going with an African Outback roof rack, like probably the half size one. I only have inches left between the roof and the garage door.
The African load bars ar a bit of work to remove - once you dial all the adjustments in it takes two allen head bolts to remove - while this doesn't sound like much (it does take some time) it will also add a bit more height to your set up.
I have to also remove these if I want to be in the garage and work - I have about an inch or so of clearance to clear the header (84") with the 4" slee springs
Hi Dude,
Do you take the load bars off when you remove the tent? Without the tent do you get much wind noise from the load bars by themselves?
Thanks
