AFM or Plug wires
Would a bad distributor cause this ? Back to the drawing board
You're getting spark and fuel and you obviously have good compression because it was running OK before you started replacing parts.
Check the rotor; you may have positioned it incorrectly.
-B-
Call CruiserDan or the above direct number to Toyota Publications or get the electronic version at TIS.
-B-
-B-
Rotor only goes on one way. Im getting spark when I grounding the plugs. But whos to say if its the right amount and in the right order ? Yes the firing order is correct, I check every time I look at the thing.
BTT: for those that didnt see the post last night.
So last night I put in a circuit opening relay. Still no dice.
I sprayed a bunch of starter fluid down the intake hoping to get a backfire or something. Nada. So I wonder if the spark plugs arent getting enough spark or at the wrong time for some reason.
