Advise for a newb
Alton, IL (near St Louis, MO)
Have been lurking about for awhile and have a couple questions. 1st I have a 1995 80 that has 156xxx and is in need of some shocks. It wallers about when cornering, bounces, and bottoms pretty easily (all on the road). I would like to do the 2.5" OME but do not have the funds and prolly won't for awhile. I have an Arb front bumper and a friend is fabing a rear (heavy). Prolly won't get much heavier as I intend to do light wheeling on dirt/mud trails very little rockin. For sure will not go bigger than 33" in the future and maybe just stock. Right now it is my DD but plan on getting a beater for work. Should I try to go with OME shocks only so that I can lift it later or is there a much cheaper shock that is decent to get me by for a couple of years. This rig will see more road use than anything but have some light wheeling asperations.
Secondly my cel came on, a friend put his matco reader on it, it said either the cats or oxy sensor. A little before this I noticed the engine being a bit more noisy in the 35-45 mph range and when sitting at a stop light. Not like tapping but rough, don't know how best to descibe it. It is not trying to stall. Any thoughts? Thanks in advance.
Now that I caught my breath, glad to be hear.
Welcome!
Do you happen to know the exact CEL code? It seems like at least one of the O2 sensors does go bad with 120K+ miles. If that is your problem I highly recommend getting OEM O2 sensors from CruiserDan. It's not worth messing around with the generic bosch ones and you might end up costing more in the long run. Don't ask me how I know, lets just say it was before I found this site.:doh:
I'm not sure if stock 80 springs will make OME shocks for the 2.5" kit bottom out too much or not. If you keep a good eye on the classified section you can sometimes find some used OME for a good deal. Personally, I'd just wait until I had the funds to do a lift because unless the ride is too much to stomach. Especially since you are getting a different car for a DD.:wrench::wrench:
As for the shocks, I would leave them for now and get just the springs. Even before adding the bumpers. If they are that soft now, when you add the bumpers you might find it sitting on the bump stops. Yes the shocks you have now might not be longenough, but it will handle better.
Do not know of the other.
Paul
... or is there a much cheaper shock that is decent to get me by for a couple of years.
A set of 4 stock Toyota shocks from Cruiserdan were around $100 a couple of years ago. I haven't seen a recent price posting but I'll bet the price hasn't gone up too much.
-B-
Welcome!
If you are waiting for a while before the lift I would just replace your shocks with something that matches your stock ones.
Sounds like you're trying to build your rig similar to mine.
Concerning the shocks, you can build it right, or you can build it over. It's up to you. The OME's spec'd for your build should work, as they're regular length for the 2.5 lift. Any higher, and you need the extended length OME's. You could put the OME's on now, and improve your handling right away.
Concerning the CEL, the consensus here is that, at that mileage, if the 02 sensors are original, they should be replaced.
The ECM could be causing the engine to run "rough" if the 02's are baked. A hint here, don't try to save money on the sensors buying Bosch or other, get the OEM's from Cdan, he'll do you right.
Oh and, get BOTH of them.
Oh and, Welcome! :flipoff2:
Thanks for the welcome wagon, have been on some forums where you are treated like s^*t just for being new. I posted before leaving work today and as I was driving home was paying closer attn to the rough spot, I can better descibe it as vibrating + a bit more loud in that 35-45 window. Also very noticable when at a stop light in drive, put it in neutral or park and it smooths out. Will have to get the exact code from my bud (should have wrote it down)
Hey if cdan is listening throw me a quote for 4 oem shocks. Any more comments about either question is welcomed. Thanks again all
The best way to contact Dan is to call the toll-free number for American Toyota. They are an Advertising Vendor on 'Mud and there is generally a banner ad that pops up randomly. Check the vendor section for the phone number.
-B-
I will track down the # for cdan, thanks! While I'm at it I'll throw this out there and yeah, I'm sure its been covered and I could read all night using search (have to work tom. getting up at 4:30am on a sat sucks). Looking to get a set of tires soon, now for the $54 question of the day. Prolly stay with stock size, will see mostly road use with some dirt/mud trails thrown in hear and there. Would like to have good road manners, have good snow capabilities, and of course be competent in mild dirt/mud trails. Road noise does not bother me but tires that last 20xxx miles do (would like to at least double that figure).
You got in such a hurry telling us why you don't have time to search for the topic that has been discussed 10,000 times that you didn't ask a question.
Assuming your question is what tyres to get....
BFG AT/ko probably in a 285 or 305.
There will be 400 replies, all recommending a different tyre. Everyone else will be full of $hit and will give you wrong information. The above recommendation is all you need to know. :D
-B-
You got it Beowulf, it was the tyres. What is your personal opinion with the BFG AT/ko's in each condition described? How many miles did you put on them before they were scrap? I do try to keep them properly inflated, rotated, etc. After searching for tyers on the site (yeah, did for about an hour, you all know how it goes) I did get about 400 different ideas and feel like I'm no further along than I was when I started but I do realise that it is such a subjective issue and 90% of the wheelers out there all have diff needs, driving conditions, etc. I know there is not a clear cut answer but hearing everyones opinions/experience is good info. The only tyre I have experience with are the Pirelli Scorpion A/T's, have them on my 95 and had them on my 97 (that I lost in a divorce, :censor:). Have not wheeled with them but on road they were not bad, did well in the rain and tackled snow ok but not great. Didn't buy either set, was just what was on the rigs when I bought them and prolly would not buy them again. Got about 35xxx on the 1st rig when I lost it and was good for another 15xxx at least.
Dunno. I put about 35k on a set of 5 with 3 replaced during the time (road hazard warranty) and sold them to a friend who now runs them on his T100 and he says they are still in good shape.
-B-
