Advice on Headlamps
Indiana
I need some advice about these headights, I need new assemblies and decided to take a look at some after market stuff.
Any opinions?
or
this style...
I'd like to find some Depo's but those seem to be in very short supply.
Euro Headlights - Chrome Clear w/o Corner Lights - 1991 Toyota Land Cruiser Euro Headlights
Any advice about headlights would be great. On mine the adjustment gears are SHOT. I pulled them apart, and the plastic gears on the assembly itself were so tight that they stripped the gears on the adjustment bolt..
The rig I just bought has some of these on it. I bought it from dixie_cragger, he might have some insight into it.
Any opinions?
or
this style...
I was in the same boat as you. I ended up purchasing the set you are looking at, except the chrome variant. They are much nicer than I expected them to be when I took them out of the box. I dropped the idea of the Depos since I was going to run HID's and projector lenses will perform better for this. So, I installed a set of 55w 4500K HID kits in the low and high beams. The light output is incredible and the cutoff is good. I was going to purchase a set of Hella Off Road lights and now I am havng second thoughts. It is scary how much light output my 80 has when the lows and highs are on. I don't think I need aftermarket off road ights anaymore.
Here is a pic of my 80: Also, here are more pics...HID Install Pics
Well, I purchased them. I would have liked the chrome ones, but this is all that I could find. Now the only question I have is... Did the lamps come with bulbs? Because I was going to wait a little while before doing the HID's. Money you know... College takes most of that away...
Also, how bad was doing the wiring? I have limited experience, I figure that its just basic electrical work, and I can do it in an afternoon in the garage. Is it anything extensive? And should I buy a slee electrical harness?
Where did you pick up the HID kit, and what am looking at for price?
The lights did not come with the HID kits. They only come with the halogen bulbs which happen to be H1 for the low beam and high beam. The wiring is not very hard at all. It is just a matter of understanding what each item performs in the setup, and then you will have little trouble. Just use good quality connectors and wrap everything well. No, you do not need to buy anything special if you decide to upgrade to the HID in the future.
I bought the 55 watt 4300K HID kits from DDM tuning for $40 each and they come with a lifetime warranty. You can get the 35watt kits for $30 if this is the route you want to go.
Has anyone done the HID conversion like MikePL's tutorial?
https://forum.ih8mud.com/80-series-tech/182029-tutorial-hid-conversion-bling-headlights.html
What are the benefits of the retrofit, instead of just sticking HID's in the housing as it comes?
I guess this is what he wanted to do. The projectors the lights come with are plenty sufficient for lighting. I actually have a spare set of projectors from a Lexus sitting in my attic. However, I really don't think it is necessary to install them since the light output and cutoff are good, so I don't really think there is a huge benefit.
Any opinions?
or
this style...
I am running a pair of the black ones with an eBay 12K HID's. I have to say that I love them! Two things:
1. I regret buying the lights with the LEDs at the bottom. They are NOT worth the extra ~$70 I paid...and they feel very Honda like. If you can find the ones without the three LEDs, buy those.
2. I had to modify the housing slightly to run the HID bulbs since the are a bit fatter compared to the factory bulbs.
Here is a pic:
Thanks!
Well, that was the only set I could find, so I bought them. How the the wiring for those work? How should I connect them?
How did you modify the housing? Just widen the opening?
Here is a pic:
Wow! Those are nice... Got more pictures?
Basically the hole that you drop the bulb into is too narrow...it is actually more of a cross pattern...you'll see once you get them. I took a file, and started filing until the bulbs slid in there without any clearance issues. Then I vaccumed up the metal flakes that fell into the projector. Depending on the HID kit you buy, you may not need to do this.
I also forgot to mention that I am running a yellow JDM bulb for the brights.
For wiring, make sure you use seperate and factory grounds for the brights and low beams. I tried to simplify by using a single ground, but this just confused the car and it said the brights were always on.
Has anyone had any trouble adjusting their lights so that the light pattern is Correct?
Do you have any pictures of the light Pattern? I'm having a slightly tough time trying to figure out how to adjust them properly. The light patter seems off.... this is W/o HID's just the regular halogens that came with it.
Wow, those lights look really really nice. I'm liking the look of the blackout ones, especially on the white 80. Arjun....I'll have to take a look at yours sometime in person. I'm surprised that everyone says they work so well.....For as little as they cost, I would of expected them to be pretty low quality. Good to know! Now I just need a couple hundred extra bux!
I just ordered a set ... ha. ( needed new headlights and corners anyhow ... )
@dimkaPDX - For the LEDs, you could always snip the wires going to them couldn't you ? So that they aren't on. I'll look when I get mine if it's an easy snip or not.
And thanks dimkaPDX for posting the extra pics that are close up to see ...
Correct...I just bundled up my wires and taped them to the side without connecting them. It is not necessary for them to be hooked up for the other lights to function properly.
For my LED's and Halos I wired them with the parking lights, they work great. I need to post some pictures up......
looks nice man. May be a dumb question however will these work for a LX and do you have to run the HID or can you stick with HIR's?
Thanks
