Hi all,
Sorry if i'm a bit long-winded here, but here's the background to my dilemma .
I've had continuous bad luck with my build and am now about to rebuild my 2002 1HZ (in HZJ78) for the third time.
The first time was a standard rebuild when i first bought it in a non-operative state. 20,000km later and a few km out of a workshop, the bottom cab heater hose 'mysteriously' blew off completely whilst on the highway on a test drive for my new gearbox, leading to an overheating disaster in the rear cylinder a few seconds later.
The second rebuild was on the premise that the head was tested as ok by the rebuilder. To make the best of the worst I added 1HZ-T pistons, gaskets etc. and a 1HD-T boost comp for the standard 10mm pump. Once fitted I added 3" SS straight through exhaust from turbo (AXT garret water/oil cooled), 2.5" PWR front mount air/air intercooler, increased turbo to 13psi, max tuned the pump to the point where compensator achieved max difference between min/max boost, dynotuned down to approx 180hp at the flywheel after getting around 200hp. I was happy as Larry until with less than 3000km on the clock another symptom apparent from day 1 came to a head, literally. While the motor ran perfectly, i was losing coolant from the overflow, initially dismissed as they lost my radiator cap during the rebuild and replaced with one lying around, but when the new cap arrived, and the same day seeing the problem in action when on the dyno (exhaust gas in the cooling system), it became apparent the gasket or the head was dodgy. To cut a long story short, the head is cracked, the rebuilders re-torqued the head bolts to 100Nm hoping it could be the gasket which made it worse (one cylinder stopped firing) and have now wiped their hands of any responsibility and I'm getting it pulled apart and rebuilt elsewhere.
Now to get closer to my question after that long introduction... Again to make the best of the worst I'll be ceramic coating the pistons, having the camshaft and new pistons balanced and I might remove that division on the intake manifold. My initial reaction was just to buy a brand new identical head from Toyota (11101-17050), but then I looked into the original 1HZ-T head (11101‑17030) but its discontinued as I expected, now replaced by another for European landcruisers and coasters up to 1999 (11101 - 17010), and i know other pre 97 (11101‑17011) and pre 99 (11101‑17012) heads exist for general market models as well like the 80, which some say were better (stronger).
So here is my question finally, in the interests of improving reliability for what will be a 3.8t world tourer, is it worth me looking into another head option from a pre 99 1HZ or even a 1HD-T while i have the chance? I know one bloke in Oz did the 1HZ-1HD-T hybrid thing but being here in Peru where all parts need to be imported I'm not sure if I'm so game to try that (due to time delays caused by needing that extra part that was overlooked in the last order), unless someone can give me the complete recipe. But the older head might be a goer if it can be done and there are real gains to be had... that's what i have no idea about, whether the changes in head post 99 where really just for 1. cost/weight/emissions cutting, 2. performance or 3. both, I suspect 1 or 3. all i have read on LCOOL is that most 1HZ turbo head problems arose sharply in the post 99 engines with the new head and pistons, but i don't know the details. if it resulted in no performance improvements l'll consider it.
So what would you do in my position? I'm in Peru so other motor options aren't an option.
Cheers,
Cheers,
