LandTank is in the process of building my truck.
I am requesting that a dual battery setup with two (2) Sears Platinum / Odyssey Marine Batteries - Group 31 Size if it will fit. 1150 Cold Cranking Amps and 205 Minutes Reserve Capacity.
DieHard Marine Battery, Platinum PM-1 - Group Size 31M - Model PM-1 at Sears.com
Also, based on recommendations, I am having a 150 Amp Sequoia Alternator installed.
Since Rick is installing a hydraulic Winch, the Dual Battery setup is primarily dedicated to my Radio Gear and any outboard electrical equipment I may install in the future.
My application is as follows:
1 - Radio Gear. My Radio will draw 65amps when keyed down with the Radio Amp ON ... maybe more when modulating. It will draw 25 Amps with the Radio Amp OFF. I will use it when required in remote location with the Radio Amp ... so I need to be capable of at least a 65amp draw off the secondary fuse block.
2 - Refrigerator. I figure about 5 Amps for this.
3 - Cell Phone Amp. This only draws 2 Amps.
4 - Secondary Lighting & Electronics. 20 Amps if that much.
** 100Amps may be required in total to cover any given scenario.
My current thoughts for the dual battery setup is to run all of the above off an isolated 2nd battery. I would keep the primary battery for starting, lighting, and normal truck operations.
I thought about using the second battery for my secondary lighting as well, but I see no reason why I would need / want to do that. Besides, it would probably make the install more complex. I want to keep things simple. All of the items above are being wired after the fact and could more easily be routed to run off the 2nd battery.
Any suggestions on the best approach and best equipment to use?
