Advice for Frame repair
I am working on a restore of a 1974 FJ40. The frame is in good condition with the following exception:
The crossmember that has the bend in it to avoid the drive shaft had been cut away.
I am not sure why the PO would make this modification. The drivetrain is still standard.
Regardless, I need to find a way to fix it. I have not been able to find specs on the piece. Even if I am able to find the specs, does anyone have any idea where I could have a piece like this bent.
Any other ideas on how to fix it? Is it not the big of a deal?
Thanks for you help.
its easier to remove the tranny and t case with c member out since its cut make 1 that bolts in then you can remove tranny easy a good muffler shop may bend the pipe for you i use 1 of those 100.00 benders from china and it works ok or post it in wanted maybey someone has 1 they will sell good luck
I have one that I cut from a 72 frame. it will fit your frame but you will have to roll it over alittle more than the way it was in order to fit the 4 speed trans. How much of the tube is left on your frame? This one was cut off about 2 inches from the frame.
The 72 and 74 tube are the same size just the early tubes had the hump for the drive shaft all the way across.
Kevin
If you want it back to OEM, then just weld in a replacement from a scrapped out rig. It's not like this crossmember is a part that gets damaged or worn out.
Mark...
