RockCrawler.com Advance Adapters TJ & JK Cable shifters and Atlas 4speed re-release!
Jeep TJ Deluxe Cable Shifter: Finally there’s a*solution to*alleviate that problematic Jeep TJ transfer case shifting mechanism!* Advance Adapters now offers a*heavy duty shifter designed to correct the binding, hard shifts, and slipping-out-of-gear that is inherent when lifting a Jeep TJ or when altering the drivetrain components.* The kit replaces the body mounted mechanical system [...]
Finally there’s a*solution to*alleviate that problematic Jeep TJ transfer case shifting mechanism!* Advance Adapters now offers a*heavy duty shifter designed to correct the binding, hard shifts, and slipping-out-of-gear that is inherent when lifting a Jeep TJ or when altering the drivetrain components.* The kit replaces the body mounted mechanical system with a robust cable actuated designed that creates a crisp and carefree shifting experience with your transfer case.* P/N 715543-231 or 715543-241.
Jeep JK Cable Upgrade:
Advance Adapters now offers a new deluxe cable shifter upgrade for Jeep JK vehicles.* This new heavy duty design was created for the off roader who is constantly shifting the transfer case in and out of various ranges.* The improved cable & mounting system offers both a durable and dependable system that removes the easily worn out or broken factory cable system.* P/N 715596.
Atlas 4 Speed:
For a while now,*questions & anticipation has been building*around the availability of the ‘next generation’ Atlas 4 speed.* Well, wait no longer.* Advance*Adapters is happy to announce the re-release of this epic product.**Some*progressive*features include a new planetary shift mechanism,*the*input gear & planetary shaft*supported by tapered roller bearings to accommodate the higher thrust loads*of larger*engines & tires being used today, and*a 300M output shaft.**Still in development is a*flat towing lubrication system which will be an upgrade option for all versions of Atlas cases.
Link
