For those of you who have adjusted your own valves, how long did it take you?
Last night I read through my FSM (thanks nate!) regarding adjusting the valves. I doubt this has ever been done on my vehicle so at 179,000 I think its the next thing I should get into.
checking not bad, along with cleaning the TB, tune up PCV system, vac system checkout etc it is a good leisurely Saturday job usually they do not need adjustment, if they need adjustment will take tearing into it twice or waiting with the engine apart wile shims ship
Raven, you think those shims have to be shipped? Thats good to know. I better check around and see if there are any shims locally before I start the job.
You say that usually they don't need adjustment but I doubt mine have been touched for 180,000 miles. The owners manual says that checking the clearance is a 60,000 mile maintenance. Are you guys doing it at this interval?
Many have checked their valve clearance. Some during routine maintenance and the others during HG replacement. I only remember 1 person that had to have a different sized shim and even that one was to put the clearance back in the middle of the range (IIRC, it was borderline on 1 valve.) There may have been others that I cannot recall but very few have found their valves out of range.
FYI, the design of the 1FZ-FE has a built-in "auto-adjust" as the engine accumulates mileage. I cannot remember the details... something about the pucks wearing and there is a corresponding 'something' that wears at about the same rate...
Mine have never been checked at 166k miles. I should do that one of these days.
Anytime you have the valve cover off, you should check them. They do go out of tolerance and they're easy to check, so at least you'll know where you stand.
If your not hearing valve lash noises or have a dead miss from valves being tight then your good. When I used to work on Europeans I HATED the Jaguars! Had to get them good and hot and check valve lash,pull the cams,pull the shims,measure the shims,relocate the old shims where I could for new adjustments,go to the dealer for the new shims,put everything back together. Then I would run it hot again pull the valve covers,remeasure to make sure it was right. It was the same way on Porsches. The BMW's were easy,they were adjustable. If your pretty religious about your oil changes then your valvetrain should be holding the specifications pretty good.
