adjusting TPS and another TB question
Here....mostly.
So with my Throttle Body removed I decided to test the TPS as others here seem to have had similar acceleration issues resolved this way. Bought the Feeler Gauges, and Vaccume Tester and went right in. Everything checked out however and I was a little disappointed I have to admit. THEN I NOTICED SOMETHING I'D SKIPPED.
Step 2b in my book - Check that there is no clearance between the throttle stop screw and the throttle lever in the closed throttle position.
I had a significant gap in there that allowed the previos tests to pass, but once the slack was taken up...it needed adjustment. Funny thing is that it still had all the factory dabs of paint on the set screws which tells me it's always been that way. Who knows...just wanted to point it out for anyone that searches in the future.
QUESTION: How much pressure is the "No.2 Water Bypass Hose" that connects to the TB under. Mine seems quite cracked up but there's no markings on it as to what I should replace it with....any ideas?
Thanks
Thanks
I can only guess "not much" since my original hose was only held on by some wimpy spring clips, and not very tight at that.
Thanks Tom,
Talked to Dan...it's under the same 14lbs as everything else. But since it's already been replace with the SC install, a new piexe of 5/8 fuel/water line will fit the bill.
