Adjusting the parking brake
Fayetteville, AR
The parking brake on my 82 FJ40 hasn't worked in a long time. It would only pull up about 2 clicks on the handle before it wouldn't go any farther. I took the drums off of the back and knocked the pieces of the parking brake loose where they had rusted into place in there until they would move fairly easily and now the handle will move about 7 to 8 clicks, however the parking brakes still do not hold the vehicle; even on level ground, I can easily push it as far as I want. How do I tighten up the parking brake? Thanks.
Bandy, His parking brakes are the drums on the rear axle since he has a late model 40. Totally different than yours and mine with the transfercase mounted parking brake. Charles, You may want to just replace the dog leg parts of the parking brake system that were frozen. They tend to rust back into place pretty quick and usually have limited movement after rusting in place. If your rear brakes are adjusted properly along with the parking brake you can get it to hold the truck on a hill very well.
