Is there any way to adjust the tension on the gas pedal so there less play in it?![]()
Less tension??? dude there are some things you don't mess with...to me it is gas pedal and brakes!
Does the LC go when you push on the pedal? if so.....it works![]()
Yes, it goes when I push the pedal. I am not used to the light touch of the pedal compared to my other cars.![]()
Light touch? Um...we call that 400 ft/lbs torque!![]()
You can actually feel your windshield wipers through the gas pedal???
Either something is wrong or you are by far the biggest princess and the pea!!!!!
Seriously, go out to your LC turn it on, put your foot on the gas pedal and turn the wipers on. Than tell me if you can feel the thump your wipers make through the gas pedal. If you can't than I do need to take my truck in because that means there is a wiring problem.
It was a joke
I tried it and no odd sensation to me. I dont understand the correlation because the pedel is just a spring and a TPS sensor...no cables lat all. The feel of the pedel should be the same in 4HI 4LO engine off or on...doesnt matter.
Good luck with the service!
I wonder if it's the relay switch for the wipers and it's near the gas pedal. Does this make any sense as I am not a mechanic?
I called Toyota this morning and talked to someone familiar with the LC200. Anyways, I told him about my problem I stated above. He reassured me this is pretty normal because the wiper motor/wiring/fan motor are all located right behind the firewall near the gas pedal which is causing that light sensation of feel I get every time the wipers are on. If it gets worse or when I need my next service he will look at it just to be sure. My next service is about 2500 miles from now and will have it checked out just to be sure the wiper motor is not touching anything the gas pedal is connected to. "I bet it is".
I don't care how much I paid for a vehicle or what kind it is, but if I felt the wiper movement through the gas pedal, that vehicle is going in.....IMHO![]()
Wrong order....-->
