Crank mark at 0* keyway at 12:00. Shiny links on chain are directly opposite each other, so there's no wrong way the chain goes on. Crank sprocket dot will be at 6:00, and cam sprocket dot will be at 11:30. Dist rotor pointing more or less at the little clip bracket that holds the wire connector that comes out of the dist.
EXACTLY
read this Hilux at least four times.
And I am not trying to confuse you, if you are confused by this, just disregard it. just trying to help:
on the cam GEAR, there are marks that line up at 11:30, like Jerod said. the cam PIN is lined up at 12:00 (or 0:00 depends on what country your from
) these two marks will never be aligned, you must reference from the arrow on the rocker assembly to the cam PIN.
