Adding winch to Non-winch ARB bumper
Oklahoma
Hello all, I have the non-winch ARB bumper and wanted to add a winch to it. I looked at getting and ARB winch ready bumper but didn’t want to spend an additional $2,000+ just for this accessory. I decided to try and fabricate a bracket to hold my winch while also being strong enough to not bend the metal on the bumper. Here is what I did. I cut some 1/4” sheet metal to fit the underside of the bumper as well as some angles pieces to fit to the ARB frame rail arms. This took a while to measure, cut, grind, and weld together. But it ended up pretty nicely IMO.
I considered just buying a standard winch plate to attach to the frame rails but the winch sat too low, and the fair lead would be coming from the bottom of the bumper, right where the pre-cut out flares are on the bumper.
After I welded everything together and cutting holes for the winch bolts as well as fair lead hole I ground down the front of the bumper where the paint bubbles during welding. I then painted over it with enamel. It’s not perfect but good enough for me, you can still see where the old paint bubbled a little but only if you look hard enough.
I did some test pulls with the winch a couple nights ago and was able to totally lock up my brakes and skid the car across pavement without the bumper bending. I am very happy with the results. I figure if it can drag my car across level pavement then I should be good unless I need to winch my car up a tree haha.
Here are some pics of what has been done, keep in mind I am an amateur welder so give me grace. The red lines are the sheet metal I had cut out and welded for reference.
My winch is an Ironman4x4 frontier 12k synthetic. I attached my control box on the inside of my bumper and made the cables pretty and discrete. The winch is upside down in order for the fairlead to run through the upper/middle of my bumper. I think it looks very sleek and minimal while also very functional. Lmk what you think!
