Installed the Vais Tech SL3B in the 200 last night. Disconnected negative battery terminal first. Then I removed the Nav and the radio, and plugged the VT harness into the back of the radio, and factory harness into VT harness. I was stuck at first because I was looking on the back of the Nav for the proper port and couldn't find it. Then I realized the radio is actually below it and had to remove a couple more bolts to get it out and see the back of it. Plugged it up, programmed it, tested it, ran a USB-Lightning charging cable from the VT unit down and out right in the corner of that pic Archtaan posted above, near the AUX port. There is just enough space for the VT box to sit behind the Nav display, and below that top center speaker. Also a good place because to access it, all you have to do is pull that top speaker cover and remove the two screws for the speaker. Although, I never needed to access it when I had it in the 100. Anyway, it works great, Im happy, and I managed to put it all back together without scratching up any of the console or trim.
I like this set up because I have full streaming capability and iPhone charging and both my cig lighters and AUX port are open and unused. Less clutter.
This first pic is from after I pulled the Nav, but before I pulled the radio......
This 2nd pic is from the driver seat with the silver VT box in the middle of the pic, the Nav back in place, and the black USB cable running down......
Looking down at the VT box sitting under the center speaker.....
