accelerator pedal stiff/sticking
Check for obstructions around the peddle. Otherwise, its probably time to replace the cable.
Disconnect at the intake, remove the rubber cap, dribble some liquid graphite down it, reconnect, deal with the slight smell from the footwell for a day until the carrier evaporates.
DougM
If doug's tip doesn't help, replace cable.
I tried, and eventually just replaced the cable and it was slick as a babys ass.
make sure to clean the tb first before you change cables, this is a common issues with toyota's and doesnt take much to remedy, if that makes no difference then do the cable
