accelerator/cruise cable specs?
Pacific Northwest
Anybody know the specs on the Accelerator, and cruiser control cables for adjustment? I had my engine out and the cables got out of adjustment. Per faq got the throttle cable back to 1 mm. Have things opened up here at work with no fsm.
Tried adjusting the Accelerator cable to the same specs as the throttle cable....it was interesting to say the least.:hillbilly:
I think you have confused the throttle cable as the kickdown cable for the trans. I adjusted my accel cable to have nearly no slack and it works fine.
Karl
Karl
Yes the throttle cable is adj. per the faq. Thanks got the Accel cable adj. What about the cruise cable....the same no slack?
My speed sensor is not working which may be causing my problems....... Sometimes the speedometer works.....
