Accelerator Cable Assembly - 1969 FJ40
Colorado
I am second-generation original owner of 1969 (8/68) FJ40 with all original equipment. The cable connecting the accelerator to the carburetor broke today just above the "barrel" that the cable passes through at the carburetor end of the cable. Luckily this happened in my garage, so I was able to recover the barrel and set screw. Since this is the original Accelerator cable, I do not know how the assembly is supposed to look and if I have all the parts. I am attaching a photograph that shows what I have and how I temporarily assembled the cable so that I could go out for a short run today. There is a small machined block that has coarse threads inside it with a screw, spring and cotter pin that holds the block in place on the fuel throttle linkage. I could not find a decent diagram showing the various parts that connect the Accelerator cable to the carburetor throttle.
I would appreciate any photos or descriptions of the parts that should be in place. I feel I am missing whatever screws into the small machined block. Thanks in advance for your help!
I have some small diameter braided stainless steel cable I have used many times to make new inner cable. A small bolt drilled crossways with cable diameter hole clear threw, then drill about half way threw with 3 to 5 sizes up drill. Insert your new cable threw the tight end (little hole), use small pliers to bend each wire of the cable back on to itself about 1/2 bolt diameter. Pull the bent over bundle of cable back into the larger drilled recess. Solder with low temp silver of melt zinc pennies into joint to lock in the bundle of bent over cables.
Cable luber tool is useful to clean and flush the inside of the the outer housing and then to apply cable lube.
