AC with a 350 V8 conversion
Use all of the stock hardware as far as hoses, evap and such and at the chevy compressor side of the hoses have a shop swap ends to mate up to the chevy. Your Toyota wiring can be used to trigger the compressor on and off.
in australia,marks 4wd adaptors make a mount to use the factory 60 series air con gear,which holds the toyota air con compressor in the right spot on chevs,making it all bolt on
I saw that on their web site....does that work with the single belt drive that the modern GM V-8 engines have?
