AC Vent Louvres Misalignment (Solved)
DFW
I knew my A/C vents were toast prior to pulling my dash apart - louvres misaligned and unable to be positioned, flopping up and down, and dirty (hooray no cabin air filter). Since I couldn’t find a new LHD driver side replacement vent for a 94 (or older, our dashes are special), I was forced to make my own solution.
This will work on any 80 series vent where the louvres do not align.
What you’ll need:
  • Zip tie(s) - I used Steelgrip 8 inch resealable cable ties (3004720) *the wider the zip tie, the more restriction the louvres will have*
  • Scissors
  • Pick - or something sharp to make a point
  • Power drill
  • 6/34 drill bit
*Warning*: The plastic is brittle, be careful and take your time.
  1. Remove upper dash
  2. Remove vents from upper dash
The vents became misaligned because a really thin piece of plastic strip that sits atop the louvres more or less disintegrated over time.
  1. Break away those remaining bits of the plastic strip.
    IMG_9290.heic
  2. Align a zip tie against the top or bottom of the vent and mark the center - that’s where you’re going to drill your holes in the zip tie
    IMG_9289.heic
  3. Depress the hole locations with a pick so the bit seats in the center
  4. Drill said holes - I found that a 5/64 bit was the happy place for the little posts on the louvres. This is an example of what it will look like before installation.
    IMG_9292.heic
  5. Once the holes are drilled, you just line them up with posts and pop them on with a screw driver or the pick for leverage.
    IMG_9295.heic
I went through about 3 zip ties before I was happy with the alignment.
Also, if your vents are flopping (up and down), they can easily be fixed with Outsane’s vent bushing thing. You’ll need one for each vent, I think… actually, check your own vents before you buy extras.
Vent bushing thing - https://solvefunction.com/shop/ols/products/vent-bushing-thing
I think there were some other solutions here that mentioned super glue - didn’t want to go that route, maybe it’s easier? Anyways, hope this was helpful since this seems like a common issue.
  • Like
Reactions: JSX
