AC Troubleshooting
Cedar Rapids, IA
1992 FJ80 3FE 234k miles
Haven't had AC for 6-7 years. I know I have a leak somewhere in the system but I'm not sure where. I know because it wasn't blowing cold so I had freon added. I don't know for sure but I have a sneaking suspicion that R134 was added instead of R12. I have NO freon in the system right now. I want to diagnose where the leak is and get my AC running. I honestly don't care that much about the AC but it also affects my defrost in the winter.
So my question is: Where do I start? I know very little about AC. Thanks.
Diagnosing and repairing your A/C does require some specific tools, a set of gauges and vacuum pump at a minimum, so if you don't want to make the investment, it might be better/easier to take it to a shop. You can rent the tools, but you do need to know how to use them. Initially, give the system a visual check: look at the hose connections, the compressor body and the condenser for signs of leaks, oily residue or wet/dirty areas. Often when there's a leak, refrigerant oil escapes with the refrigerant and then dirt will stick to the oil. Many leaks occur at a junction of a hose connection which is sealed by an o-ring. Generally replacing an o-ring is pretty easy. If the compressor appears to be leaking, you can re-seal yours or buy new (roughly $275) and replace the drier (located by the battery) also. Once the leaks have been fixed, the system will need to be vacuumed to remove any moisture, and then charged with R12 (Craigslist is a good source for finding some). In a best case scenario, the system will work and not leak. Realistically, if you take it to a competent shop, they can charge the system to both check for leaks and see if the system performs as it should, then recover the refrigerant if repairs need to be made. This is obviously the extremely condensed version of repairing your A/C, but there are plenty of threads on it if you search.
To aid with leak finding ask the AC guy to add some dye, you then use special glasses that make the leak show up like a bright light, my slow leak was a pipe that had gone ever so slightly porous, being above the exhaust it would dry out as we were looking for it but it left a yellow stain only found with the glasses.
regards
Dave
