AC Troubleshooting
Chesapeake, VA
Website
themethodstudios.com
I recently replaced my compressor, recharged the system and had AC for the first time in 7 years.
It held the charge and worked fine for about 5 months and one day I cut it on and it blew warm air. It ran for a few minutes at normal running temperature, etc. And still warm air.
I figured my first step was to charge it again and if it blew cold I had a leak somewhere. So, I went home and out the can of coolant on and before I could start putting any in it blew the can across the driveway. The hose split, going from the can of coolant to the connection.
Any ideas? I'm perplexed. Also, it's a '92.
Thanks.
I'm guessing that you connected to the high side of the system rather than the low side. You want to connect to the port next to the larger diameter hose, not next to the smaller hose. When you press the A/C button, does the front hub of the compressor engage and start spinning? If so, then the system has refrigerant, and it's time to look at the sight-glass (it's in the liquid line) and if you see bubbles, it's low on refrigerant. Is it still R12? If the hub doesn't engage, then it could be that there isn't enough pressure to close the pressure switch, or there could be some electrical issue that's preventing the compressor from engaging. If you put dye in the system, use a UV light to check for leaks.
Good luck!
Rex
