AC trouble
MA
I have a leak somewhere in my A/C system on my 1996 LX450. At first, it appeared to be a failed o-ring at the condenser inlet because there is oil/gunk residue near that inlet. It could also be that the condenser itself failed with a crack there as well. I changed the o-ring and the leak still exists.
I guess I need to put in some sort of UV dye to determine the actual leak. Any areas prone to leaks?
Since I will have to do an overhaul of the A/C system, what should I do? What parts should I purchase (CDan)?
If you wheel your rig then this would be a good opportunity to relocate the A/C drier. It is located behind the front bumper on the left side of the vehicle. There are several posts describing options.
If you don't wheel it then this mod is unnecessary.
-B-
