AC ticking noise
Grass Valley, CA
I've just noticed a ticking noise under my hood after the AC is running. When I look under the hood it seems to be coming from the area where the belts are. Also, the AC is not predictable with temp since this started. First Cold from center vents and just luke too cool from side vents, then no cold, now all cold. Any thoughts?
Thanks,
Teresa
AC Belt slipping? or Fan Clutch maybe?
Perhaps one of the more experienced people might know more...
I recently had my compressor replaced. Later it started clicking like an aerosol paint can with balls in it when you shake it. Turned out the tensioner bolts had backed out. Might want to check them out.
Teresa
Check the tensioner pulley on the A/C belt. I just had to replace mine as it had completely frozen up. You should be able to turn it easily by hand. Undo the lock nut in the center of the pulley then use the adjustment bolt on the back side of the pulley to let the slack out and remove the belt.
Report back and we can go from there.
Well, from my limited experience...mine was making the same noise. It was ticking/clicking/tapping, whatever you want to call it (sounded like bad bearings) and I originally thought I had a problem with the compressor. It was like this for several months until a week or so ago. Then it was a flapping sound all of a sudden and then my A/C died. I looked under the hood and saw that the belt had been shredded. Luckily, I had a replacement belt and put it on and no more noise and my A/C works again! It is easy to replace, just take the 4 bolts off the shield/plate on the underside and loosen the tensioner to get the new belt back on. Hope it helps you out.
