AC Servo Part Number Verification
Merrifield, Minnesota
Now that MN temps are consistently above freezing, I'm in need of my AC unit. Since I bought it last October, the AC has been unimpressive. I did some research and came across the easy fix in the thread below and figured I would check the setting on my hot water valve. Being the valve was only closed 1/2 way, I figured that was the issue. I wasn't able to push the cable back into the sheathing so I figured it got bound up when I installed my stereo. When I pulled the dash apart I could see the cable was pushed against the back of the vent and that the pin that retains the cable was snapped off. Looking at the pin I'm not sure it was OME, it looks like someone in the past had tried a quick fix. Does the pin come standard on the Damper Servo Sub-Assembly (87106-95070)?
My cruiser is 1997 40th Anniversary Edition
