AC Replacement
Boston, MA
I've been having issues with my AC on my 97 LC since last summer. I got it charged twice last year and it worked great for a couple of months. Come this spring, nothing. Obviously a pretty serious leak. So I bring it to a local garage to have it checked it and they said the system wouldn't hold charge because the AC lines are rotted out and would cost thousands to replace. I asked them to be more specific (is the condensor, evaporator, compressor, drier) rusted out also. They didn't specify and were pretty vague. I doubt they actually performed a proper leak test and suspect that they just did a visual inspection and probably didn't want to do the job. I did a visual inspection of some of the parts and they are rusty but does that alone mean they're leaking?
So I'm going to get a second opionion but was wondering what replacement cost for the AC system is on a 97 LandCruiser. Are there good aftermarket products that are suitable?
Thanks,
Nisi
97 FZJ80 w/ 237,000 miles
I would get a second opinion at a different shop. I would suspect your lines are corroded on the outside, but still decent on the inside since there is oil circulating around inside. O rings dry out over time. If your system is empty, get some o-rings and replace what you can. Autozone rents a vaccum pump and manifold set. You can use this to pull a deep vac on your system after you replace the o-rings to see if you need to keep going further with replacing parts.
I doubt it is your lines unless you had some front-end damage.
I am guessing it is:
1) Condenser (available ~$140 online aftermarket)
2) O-rings (Wendy's $1 menu)
3) Compressor (rebuild kits available)
A shop wanted $650 to fix mine last summer. I fixed it for $350 including buying a vacuum pump for the refrigerant, a gauge set, a condenser, a dryer, and a couple of cans or R134a.
My freon was bone dry last month. I replaced all o-rings $15 from napa) (minus the expansion valve o-rings, new drier ($16 from napa), pulled a vacuum and filled with 134A. Blows icy cold 46 degrees now.
I would go that route if I were you
