AC Question
Tampa, FL
I have had my LC for a few days now. Each time I get into it and start it, the AC is set back to 75º. I usually keep it on Auto at the lowest setting (Florida heat). Why is it going back to 75º upon startup? Is this how it is designed?
Check that recirculating hvac door in the glove box. Either the door gears are broken or air filter isn’t seated probably causing the door to not fully open/close (that was my problem). Either will cause the system to reset each time at startup.
hope that works for you.
Problem solved! I just checked the filter and you were spot on! It was not seated properly. I just ran the LC through two restart cycles and it was 100%. Thank you so much!
