AC - lost middle row buttons
WJR
AL, USA
The middle row of buttons went out on my AC, which is the Auto AC on a 97 LC.
I read some old threads but wanted to see if there was anyone who had this happen recently.
From what I can tell I probably need the following part: 88650-60212 Air Amplifier Assembly, Auto
However, I wanted to see if anyone can tell me what the difference is from that part and this part: 88650-60081, Air Amplifier Assembly, 96-97 LX450 and 97 auto.
Big price difference on CruiserParts.
Thank you in advance. I love this place.
WJR
All of the climate control modules have an 'auto' switch on the back. I was curious what it was on my '94, and Mud seemed to indicate that the boards are the same, but the automatic climate models have a bunch of outboard stuff (presumably sensors and relays) that the plain Jane models lack.
If I were you, I'd pull the module apart and look at the circuit board. I don't think there's anything solid state on there, it's all simple circuitry. And I assume you checked the obvious, like a loose terminal block...
gummycarbs, I appreciate your reply. The only obvious thing I have checked so far is the fuses as that had been a culprit on a few older threads. I will now check the terminal block and appreciate that suggestion!
WJR
The back of the climate control unit has two terminal block connectors:
The 'AM' label is 'auto' 'manual'. The other clear stickers cover the rear side of the bulbs. There are additional clear stickers on either side that act as tape to keep the unit together for some reason (it uses plastic latches, so I don't know why the tape is there).
The inside uses two circuit boards. They're connected by soldered (I think) ribbon cables.
Thanks again, GC. I am going to take everything apart and look closely this weekend. The air is intermittently working so this is getting to be a pain.
WJR
Does your windshield leak?
There's an ac amplifier under the drivers dash. It's a tan box above the gas pedal. Pull it apart and you'll probably find it's been filled with water at some point. It's expensive.
If someone knows a work around I'd love to hear it.
