AC help!!
North Little Rock, AR
I bought my 97 Lx a few months back with the AC not working. I took it to a local shop that (supposedly) pulled a vacuum, found no leak, added dye and freon and it worked great....for about a month. Took it back this morning and they told me I've got a leak at my compressor and the only way to fix it is to get a whole new compressor. Long story short they want to charge me around $1500 to replace "everything" because it would turn out cheaper than just replacing the compressor. WTF?
I know nothing about AC systems so any help/advice would be greatly appreciated. I tried the advance search but the info was either over my head or not specific to my problem. I'm hoping I can do this myself as money is a little tight right now. Summers in AR can be unbearable without AC.
Thanks is advance.
If they added dye you should be able to see where the leak is. If it is the compressor make sure its not just a bad valve stem leaking. Someone on here sells A/C stuff and you should be able to do it yourself ALOT cheaper.
Here's a couple options:
1) Reseal your existing compressor (how-to links below)about $30
2) Replace yours with a new one...about $260
In either case, put on a new drier ($22), and replace the schraders(<$5) and the other o-rings(<$8) in the system.
Front hub removal video
Reseal video #1
Reseal video #2
Replacing the parts isn't that difficult, then take it to a shop and have them evacuate and recharge it-or invest in a vacuum pump($99) and set of gauges($89), and do it yourself.
After watching the videos, you'll have an idea of what you're comfortable with. Let me know if I can be of further assistance.
Rex
Did they have a jar of vaseline on the counter?
FYI: Rex, (1972FJ55) is an excellent resource and vendor when it comes to AC systems. He stocks Denso (oem) parts and has good prices for Mudders. He is very responsive to questions and offers great support/advice.
times two on lookng for the leak. If you have a blacklight, just look at the truck in the dark with the blacklight and the die will be obvious. I think since it was working fine until the freon ran out that you more than likely have a slow leak at a fitting and it would be an easy fix. You might just get a second opinion from another shop if your not comfortable working on it yourself. I'd fix the leak and thow in freon and keep going. My 2cents.
I have replaced quite a few compressors,its no big deal if you take your time.Get a dryer -reciever also.But a whole new system I dont think so. What part of Arkansas? MIke
