AC Help
Yes I've searched.
I "think" I know what the problem is.
Symptoms are:
Cool, not cold air.
Sometimes no cool air, even with compressor spinning.
Clutch works, no noise from compressor.
Spins and stops when you move the switches as expected.
Took it had the pressures checked.
Was a half pound low, which they added, pressures at 210/30 when done. (On invoice...)
Seemed much cooler, almost cold, was as cold as it's been since I bought it. Drove for about 40 minutes, and it got steadily warmer, until it was pointless to run.
I "think" it's the Evap Expansion Valve, which means pulling the evaporator out from under the dash to change. Don't have pressure readings at that point as I was driving it home....
It was only about 90 degrees out.
Any thing else I should consider.
They seemed to think it was something related to the compressor, but I though it either worked or didn't.
I don't want to replace the valve (and reciever dryer) only to find out it was the compressor....
Anyone care to comment..?
Thanks,
Dennis
This is an unscientific, quick'n'dirty check: Look in the sight glass with the system running. A flashlight helps.
It should be brightly colored. If it's dark, you may have a compressor issue.
If the system was low, you may have lost oil as well. Did they put in a dye? Leak check?
Trace all the lines in the system. (One goes behind the engine, but there's no fitting, so don't worry about it too much.) Look for oily grime on or near all the fittings. Oily grime is compressor oil telling you there's a leak there. O rings go bad over time.
But your symptoms sound like a cooling system issue. Check the operation of your heater valve. It's right above the back of the engine. Has the 4 hoses coming out of it. There's a cable and lever. It should move with the temp slider on the dash.
Check the lines coming from the evaporator. They're the ones coming out of the firewall on the PS. One should be very hot, the other cold. If not, there's no longer a pressure differential. This could be an expansion valve failure, or the compressor.
No oily grime on the lines (Unless it's at the evaporator...).
Cooling system PM is due.....
BOTH lines out of Evaporator are HOT.....
Guess I'm in for some big bucks....
Dennis
Site glass is very clear, no bubbles. SLIGHT greenish hue. So slight I had a hard time telling if it really is greenish, or if it's me.
Heater valve moved with control, didn't close completely by cable. about 1/4" short. Moving it by hand closed it, but no difference on output temp. still just cool. Drove it for about 30 minutes today, really cold at first, but got gradually warmer. Never got to the point of turning it of before I got home, though.
I HAVE the Evap valve and Dryer in hand. I guess I have them do that, and hope it's not the compressor....
Will look into the fan clutch...
If both lines going to the evap are hot and the compressor is working, it's the expansion valve 9 times out of 10. Back flush it, that might get you by, but the leak(s) won't go away.
The greenish hue you see is the dye that they put in the system.
Just to finish this thread off, it WAS the expansion valve. I had the dealer I work at (Non-Toyota) do the work (and dryer, too). I just ran out of time and patience with the heat.
375.00.
The Evaporator core was filthy, I asked the mechanic to take his time and get it REALLY clean...
Funny smells are gone, and it hurts my knuckles, it's so cold...
Dennis
