AC/Heater Tech Help.
Los Angeles, CA
Website
www.phipsi.net
Hey boys. As many know I ditched my AC in total a LONG time ago. i RECENTLY removed the "Cooling Unit" (FSM pg.AC-24). Now my heater is not working?
I want to have as FEW parts as possible while still having heat.
Do I need to put the cooling unit back so that the heat works again?
Thanks in advance
Sammi
PKP80
From left DS to right PS. the units sit Heatercore then Cooling unit then blower unit.
Thanks in advance
Sammi
PKP80
Define not working.
Good point
Not working as in not blowing air.
Climate control has power
You removed the entire box on AC-24? The Blower Resistor is attached to that box. That is part of the controls for your blower motor.
Do you have an empty space there now, or did you remove the evaporator coil from the box and reinstall the box?
Check your connections, seal any holes in the duct work under the dash.
Removed the entire box on AC-24, did not put it back, but judging the reply and the fact that it stopped working it sounds like it needs to go back. I was hoping that there was a way to eliminate it (and anything else under there for that matter, that didn't need to be there).
I should remove the evap. coils and then reinstall?
If that's the direction you are going. Completely gutting the AC, leaving only the heat. Open that box from AC24, remove the evaporator coil, expansion valve, and anything else you desire. (And send it to me, I will pay for shipping :grinpimp:)
Then fill the holes and put the box back in there so your air ducts will remain intact. You will also need to reconnect the blower motor resistor so your blower motor will work.
This will leave you with two holes in the firewall where your AC lines would penetrate. You will want to cover those holes from the engine side, probably.
If you're looking for just a heating coil and fan under the dash. Like a Vintage Air setup (before cars had climate control and ducts) you could probably just wire your own switch to the blower. No idea how complicated that would be, but a 12v fan is a 12v fan. The resistor just let's out operate at different speeds. Then make some ducts to connect to your floor and defrost vents.
For the safety of everyone, if you go this route, please duct your defrost vents at the very least. I need you to see me and my family in my 80. Unless you're just buggying this thing and it's open air...
