I isolated a belt driven whine to the AC compressor by removing the AC belt.
Luckily I had a spare AC belt tensioner pulley with a very quiet OEM bearing. Swapped that in and the whine was back. Remove the belt and the whine is gone. Both tensioner pulleys were quiet and not the cause. I am currently not running an idler pulley.
I installed this Denso compressor from Coldstream back in 2008. It still blows cold but I did have to add refrigerant on occasion over the years. The compressor pulley turns smooth and quiet by hand. The compressor only whines when belt driven; no squealing, grinding, howling. I had all of that when I ran the original compressor way too long in poor condition.
Could it be that the compressor itself is just low on PAG oil? Could that cause the whine???
A new Denso is pretty cheap but I'd rather not open the system and go through all of that again if it's not necessary.
