AC evaporator questions
Arizona
When do you know you need a new one compared to rebuilding one and replacing the o rings and seals. My truck has been in the shop and the guy called and left a messages saying me evaporator is bad.
When there is a hole for one. Assuming there is no puncture, the next reason would be corrosion. Since oil is in the freon flowing through the evaporator and you live here in AZ, I would say corrosion shouldn't be an issue. Did your compressor grenade? If so, it is possible you have a partially clogged evaporator though unlikely since your drier would filter larger pieces out of the system.
Hi,
Like gotmud said, if it's got a leak-the only other thing would be if the fins are so clogged with debris that there isn't adequate airflow to cool the cabin.
FYI, Toyota used two styles of evaporators, a serpentine design, and a plate & fin. You want to be sure to use the same type as came in it, so it will fit the case properly. Both sell for about $100.
Good luck,
Rex
www.coolstreamac.com
