AC cooling help and info/conclusions?
38.0111,-109.9181
Website
www.alamosa.fm
Standard story here, at low speeds I might as well not even have AC there as it barely cools. I just had the 3rd specialty AC shop look at it and despite the r134a being down about 1oz, all pressure and leak tests come back normal. Heading in to the hell months here in Phoenix and need to get this solved quickly.
At highway speeds AC is just barely sufficient, but certainly not cool. I don't have any apparent overheating issues, HG PM'd a several years back. I have not mod'ed the temp gauge, but I've never seen the truck run over the the half mark in my 11+ years of owning it.
I am installing a pusher fan and will be adding some 10k (might as well) to my blue fan clutch, but I'm skeptical as to how effective this will be on AC?
How close does the heater core and evaporator sit to each other? Is it possible that I have some coolant flow through the heater and is negating much of the AC's effect?
96 FJZ80, no SC.
96 FJZ80, no SC.
High engine temp's will cause the compressor to cut out (noticeable if you're paying attention), not poor A/C performance.
Things I've seen people mention here that have helped an operational (refrigerent within spec., etc) but poorly performing A/C system are:
1) Pusher fan (especially at idle).
2) Clean the condensor fins really really well.
3) Clean/flush the evaporator in case it's moldy and/or gunked up. (There are easy to use products specifically made for this.)
Curtis
I had an interesting A/C experience last week. It was in the 90's here in TX and I did a little wheeling and the truck was a little muddy. I was on my way home and I didn't really want the wife to know I went wheeling, so I pulled into the the drive through car wash, Bubbles. It's one of those drive throughs that actually pulls your car through and does a decent job for $4. Well, sitting in the truck going through the wash, it felt like my A/C was just a vent blowing. When I got to the end of the wash there are these giant blowers that blow the car dry. As soon as they started blowing, the A/C temp dropped significantly and blew cold the short while under the blowers. This experience made me start considering hooking up another fan up there.
From what I see here with my 1995 80 in Cambodia where its hot or hotter year round.
If if your AC and all related parts are working. Your AC should frezee you out of the cab.
Before I bought my 80 it had slight crash that pushed the front bumper in just slightly to hit one of the AC lines and it lost all the freeon .
I had it repaired here in cambodia after it was shipped over. The AC would work good then just stop working.
They said the orifice was dirty and the screens in the lines needed cleaning. And they would pull out all of the AC and flush and clean the in side of the lines. They took every thing apart and flushed and cleaned it.
I can now say with temps near 98 some days hotter the AC will frezze you out and I have to add some Heat from the heater to warm it up some. Most days I dont run Reculate air becouse it just too cold.
At idle out side air 95 or hotter My AC compressor will cycle on and off My guess its from getting too cold becouse the inside temp never warms up as it does this and when they have the gauges hooked up all PSI reading are normal.
I am running 134a.
Dont know what type of fan hub I do know it sucks lots of air at idle but will free wheel at high RPM.
I did yesterday install a pusher fan only becouse they have 100's of them for sale in cambodia for nothing. The raditor shop installed it for $25 USD I used the Rear heat switch to run it. I like to do all my own work but the labor cost is nothing here. $13 labor to have all the spark plugs changed at Toyota dealer.
MY machanic tells me there is a theromstat for the AC in the air BOX some place. I never saw it as they did all the repairs to the AC when I was back in the USA. They said they would adjust it if it needed it?
So if yours keeps giving you problems tear it all apart clean every thing. Maybe even replace the dryer too. Becouse I know when its working correctly it works good.
I dont know if the 80's AC is one thats cycles on and off or is one that has ajustable orfices and compressor runs 100% of the time. Like the older 70's Chevys.
Brian
The first 80 I had was a 94 and it could freeze you out at idle in the Texas heat. My new to me 96 LX450 is ok at highway speeds, but no where near the level of cold as my old 94. I'm going to have it checked out. My sister has one of those fund raiser coupon books and I nabbed a coupon for a free A/C checkup, evac, and charge. I only have to pay for the coolant. I used this same coupon last year, on my civic. I got the A/C all tuned up and blowing cold for $14. Hopefully this is all I'll need on the LX.
Scott,
As others have stated on here, your '94 should blow plenty cold, even here in PHX during the summer months. Mine didn't when I first got her, but here's what I have done so far:
Added JDM fan
Replaced fan clutch wth blue version. Drained and refilled with 20K cst oil.
Cleaned condensor with Purple Power to get rid of grime in the fins.
I'm still need to clean the evaporator with the BG product used in one of the threads here.
After toasting my dryer at Pyeatt Draw, I took advantage of the system being open and flushed out the lines as well.
I'm here in Phoenix as well (not a CSC member). PM me if you'd like a hand getting your system to work.
Toyota doesn't sell it. I get mine from a hobby store that sells higher weights for RC cars.
