AC compressor not cycling off--TOO COLD!
New Mexico
I've noticed my AC has really been cold the past few weeks--so cold that I have to put the fan on low and slide it halfway between hot and cold. And, I'm here in Southern New Mexico, and the temps have been 100, + or - a few.
It's never been this cold, but I finally noticed today while sitting in the truck waiting for someone that the compressor isn't cycling on and off like it used to. Is there something to cause this, and if so, is it going to cause problems?
I can manually turn it off, and the rpm goes down, like it should, so I know it's not permanently locked.
I searched and no topic with this was there.
Thanks.
-Eddie
O.K., bear with me for a minute. I'm starting to put some things together.
I did a valve cover gasket and coolant flush a few weeks ago. I was stepping on the ps side frame, right next to the ac compressor, but don't think I hurt anything.
I've also been noticing about a 1/2 inch of resevoir loss on heavy driving days for the past week or so. Figured it was the hot temps here in NM, and have been looking at the block to make sure it's not a HG failure, and even pulled my plugs to see if they were burning bad.
Occasionally, when I start it up after it's sat for 15 mins to an hour or so, it will idle rough for just a few seconds, then will smooth out. That only has happened about 5 times within the past couple of weeks. I figured it was because I cleaned off the engine after the valve cover job, and even looked into my distributor and MAF to see if any moisture was in there, but none.
After posting the first post, I pulled up after a short drive, and man, the engine compartment was hot. But, my oem temp gauge is normal still.
So, could the rough idle on occasional startup, and the coolant loss all be from the increased temp of the AC system from not cycling off?
I've also noticed my fan clutch never has engaged in the two years I've owned the truck. It's never overheated, so I've never missed it, but I'm thinking with what's going on now, it probably should have come on.
Thanks.
-Eddie
