ac compressor/cluth question
Yes. The clutch when not engaged is just rotating on a bearing with no load. There is an electro-magnet that engages when there is power to it and that is what gets the compressor (and clutch plate) spinning.
What I meant was that the vibration is enough to sometimes make the clutch hub rotate when the compressor is off. And yes CJF is right, this would be a shim issue. BUT its not the end of the world if it does slightly rotate and is a relatively easy fix as you mentioned you have already shimmed it.
