AC Charge Question
r2784c said:
Have a 1980 FJ40 with factory A/C which needs a R-12 recharge. Does anyone know the low side pressure value that I should charge the system to?
thanks.
chad
You charge to the system capacity by weight.
Or charge til the high side is at normal operating pressure. the low side is not a good indicator, except to tell you that the charge is way too low or way too high.
I am not planning on fully discharging system, so charging by weight is out. If the high side is the more accurate way to charge system, what is the normal operating pressure for the FJ40 system?
Thanks.
chad
Thanks for the info. One follow-up quesiton...While charging (as I open the low side to the R-12 cylinder), how high should I allow the low side guage to read. I have only been opening the valve until the low side guage increases to 20-25psi.
Thanks.
Thanks.
That sounds about normal. Opening it all the way probably wouldn't read much mor than 30. I don't you'll see more than that depending on the system. Unless some control device isn't working right.
