Ac Blower Relay Keeps Burning
San Juan Puerto Rico
Website
www.facebook.com
The only time the relay is used is on high fan---the ground for the relay coil is through the controller and the fan motor then grounds through the relay contacts.
I would check the ground from the relay contacts (wht/blk) wire then I would probably suspect the controller.
Thanks! I will look into that tomorrow.:cheers:
Is the controller, you are talking about is the slide switch that goes from low to High?:hhmm:
