AC ADJUSTING BOLT is STUCK!! HELP...
Berkeley, CA
Hi all, I went ahead and tried to joined the Do-it-yourself belts replacement club. Everything went smoothly except for the AC ADJUSTING BOLT not budging to mater how much WD-40, wrenching, cursing, or threatening I do to it. I ended up screwing the entire bolt off. All the new belts are in place. But the AC ADJUSTING BOLT is so stuck that I twisted the entire bolt head off the rest of the screw. Now it's really stuck and I'm really screwed:banana:.
Soooo... What the next move?
You'll need to drill and tap it out if you snapped the head off the bolt! Next time try using PB penetrating lubricant and let it soak for an hour or so while respraying every so often. This stuff works great for loosening up frozen and rusted bolts!! You can get it at most auto parts stores.
slinger-thanks for the edvise I'll be getting that taping set today along with some better lube.
To answer the other question, I believe I loosened the pulley right but after what hapened I can't say for sure. Can you explain the "right way" to lossen the pulley.
x3... the adjusting bolt won't move unless you undo the locking nut at the center of the pulley first.
Once you loosen this lock nut, you should be able to turn the adjusting bolt out by hand with a little lub from some PB blaster, as long as you haven't boogered the threads any.
:beer:
Rookie2
:beer:
Rookie2
x4.
You might not be in any trouble at all, other than needing a new bolt.
Thanks for the replies. In all the treads I've read, I never saw anything about loosing the lock nut. If that's the case, Is the lock nut located in the center of the pulley wheel?
Yes the lock nut is in the center of the pulley. Loosen it and you should be able to move the adjustment bolt.
Depending on the condition of the tensioner pulley you might consider replacing it. It is relatively cheap and mine just failed a couple months after I replaced my belts. I considered replacing it at the time but didn't. Oh well, I just ordered it this morning from Dan.
that's an $18 bolt at the dealer, or $.88 cents at Home Depot.....broke mine recently and luckily found the cheap fix on a Sat evening.
Perfect example of why MUD should be used as a supplement to, not a replacement for, a repair manual.
Yep, this site's great for assistance when you run into a question or road block, but advice is given assuming you have the service manual.. so you typical wouldn't see (and shouldn't expect) step-by-step instructions written out. FWIW, my mechanic screwed up the same thing servicing the AC compressor.
:beer:
Rookie2
Yep, the lock nut's not obvious unless you've got a manual or read about belt service on MUD.
DOugM
Thanks again everyone for your help. I do have the Chilton repair manual. I guess I over looked the lock nut part. Thanks again.
Not necessarily, it may not be listed as a step, yet another reason I prefer in most situations the Factory Service Manual over Chiltons.
Ditto. This cost you - what? - An hour extra of your time? Plus another hour to find and install another?
DougM
