Need some help!
Model - 2005 LX
A few months back, took a pretty hard hit in a riverbed crossing and a few minutes later I got codes C1340 and C0210 (right rear wheel speed and open circuit center diff lock). I shot both loops, found nothing, plugged everything back in and issue went away.
Fast forward to today - woke up at our campsite to rain (not sure if relevant) and took the trail back home. Shortly after getting on pavement, the ABS, VSC OFF, VSC Trac, and Brake lights came on. Pulled over, learned that my emergency code reader doesn't read abs codes, jiggled the abs connectors, and unplugged+plugged the battery. This did not fix the issue.
Got home - pulled codes and have:
- C0210 (right rear wheel speed)
- C1340 (open circuit in center diff lock, note: easy trail this weekend and never locked the diff)
- C1223 (generic abs code)
- C1256 (accumulator low - this is new)
The 2 hour drive home had no issues driving or braking, pedal feels solid and no inadvertent trac or abs kicked in. I did recently bleed the brakes, so I'm wondering if theres some trapped air leading to the accumulator code. For the rest I'm stumped. Going to shoot the circuits again but expecting the same thing.
Does anyone have suggestions for where to go with troubleshooting, or have experienced a similar issue? My next plan was to check all my grounds I think.
Model - 2005 LX
