- Joined
- Aug 24, 2007
- Threads
- 4
- Messages
- 13
Hi,
I broke both front ABS sensors while rebuilding the knuckles on my 95 land cruiser. A rust ring had formed right above the o-ring and the whole sensors broke right at the o-ring. I should have just pried up from the bottom and hoped the bottom wouldn’t break. Oh well live and learn.
It looks like the front ABS sensors are only sold in a kit with the wiring harness. Do the kits contain both sides? The picture shows both sides but it doesn’t say in the descriptions. The cheapest aftermarket kit seems to be from Autozone at $350. Does anyone have any experience with them?
I am also considering buying them used. My only concern is why isn’t the sensor sold separately from the harness new? Has anyone replaced just the sensors and had any issues? The sensors worked fine before I broke them so I doubt the harness has any problems and I dread trying to take out all those rusty 10 mm bolts. Does anyone know the size of the o-ring? If I buy it used the o-ring will most likely need replaced.
Lastly is there supposed to be an ABS shim? I’ve seen some references to a shim when I did a search but my land cruiser does not have an ABS shim.
Thanks
Tobin
Thanks
Tobin
