ABS sensor housing repair
Washoe Valley NV
While disassembling the PS knuckle, I managed to break the plastic housing for the ABS sensor. It felt like a piece of dirt had jammed in next to the o-ring, I could rotate it just slightly but it wouldn't budge vertically. When I removed the knuckle I was able to easily push the housing/magnet in but not out.
The coil is still good, but the housing broke just above the o-ring. It's a nice clean break, and looks very repairable. The only problem is I am not sure what kind of plastic this is, so I don't know what adhesive I can use. I see 1996LandCruiser used epoxy: https://forum.ih8mud.com/showpost.php?p=5733950&postcount=5 but I don't know if there are different epoxies that work better than others. I have some 2-part resin for fiberglass. I also wonder if thick CA might work, or even model glue?
Who's done this repair? What worked and what didn't?
Thanks!
Well lacking any advice or better ideas I'm going to rough up the grey part and the inside of the housing, and coat the inside of the housing with hobby fiberglass resin. If the thread ends here either it worked or I died horribly.
Did it work? or....
