Abs problems
Minneapolis
happy thanksgiving to everybody.
So I have a problem. My 93 cruiser has been misfiring the abs system. So when I make some stops (on reugular road) it will just lock up for a second or 2 then stop. I read on an earlier thread that it could be the birfield. Is that All it could be? Or maybe a bad sensor. What do you guys think?
Thanks
Dallas
First thing I'd do is remove the ABS sensor from each knuckle (pretty easy to do: remove the wheel and the sensor sits on top of the knuckle, I think It's only held in by one bolt..) and wipe it clean. There may be metal shavings sticking to the sensor, this will cause malfunction in some cases.
It fixed my intermittent firing.
Lock up? Mine would cycle the ABS just before I came to a stop when I had metal shavings on a sensor tip. No tires locked up.
