ABS problem on LX450
My wife's LX450 has developed a little bit of a brake problem. I changed/bled the brake fluid about 3 to 4 weeks ago with Valvoline DOT 4 synthetic brake fluid. I was able to do a complete bleed of the brakes. The brakes have been fine since then until yesterday. Upon braking at an average speed and above, just before the vehicle comes to a stop the ABS system kicks in for just a split second causing the peddle to drop a bit and the vehicle to roll a bit. After the split second the brakes are fine to finish the stop.
It does not do this if the center diff is engaged and the ABS disengaged or if I place the vehicle in neutral and brake.
It will do it in drive, 1st, 2nd, or with the overdrive off.
I bled the brakes again to make sure there was no air in the lines and they were fine, however the problem continues.
I pulled the ABS plugs in the rear and blew them out and sprayed them CNC electric cleaner with no help.
The vehicle has 136,000 miles. Is stock and in very good condition. Not modified at all. Tires are stock size. Birffs have not been done as far as I can tell(if they have it was a long time ago).
Thanks for any help/insight:meh:
I had the same situation when I bought my rig. I believe that it is the abs sensor on one of the rear wheels. It only happens occasionally for me, so not sure if the sensor is bad or poorly installed, one day I will tear into the rear wheel and look at it.
Does this sound like it could be the problem?
2 questions.
1. What do the rear ABS sensors cost?
2. What does it take to replace these?
Thanks
Why not pull them and check to make sure they are not fouled with metal shavings? A single bolt and you can check them very easily.
When I had this problem I found I had smashed the ABS sensor wire that runs along the left control arm - found that when I replaced the two sensors and harness (comes as a matched set, I paid about $200 if I recall). I have heard of cracked ABS sensors (plastic kind, my original were aluminum). If the ABS sensors are not removed when the burfields come out, they can be damaged.
Fouling is the most likely problem. And then the question is, where is that metal fouling coming from?
1993 LC here. Before I got mine sorted out I pulled the ABS fuse to ignore it for a while.
Have you pulled the front 2 sensors and checked them? If not I'd start there. When I did my front axle service each sensor had quite a bit of metal shavings on there; due largly to improper bearing preload that completely roached the bearing races. Give them a quick clean and see if that helps.
Corey
The sensors are magnetic, tend to accumulate bits of metal and rust over time. Cleaning them fixed that exact problem for me.
A dirty sensor won't sense the wheel turning. The system will ignore it at moderate speeds and above, but when the other three wheels are nearly stopped, the system thinks one has stopped before the others and releases the other three momentarily.
Okay guys, thanks for the ideas/insight. I will do a little bit more looking and cleaning and see if that clears up the problem.
Thanks again
Exact same problem here. I assume you're occasionally having the ABS light go on during your drives, and then reset itself at the end of the drive?
Good news is that you can connect up a scanner to the ABS system and pull the code which tells you which sensor is causing the problem, so you can eliminate that guess work.
Bad news is that you probably need the dealer to get the codes pulled, as normal scanners wont do it. And I've heard of dealers charging $200 to spend two minutes to pull the codes :doh:. If you're an electrical engineer then maybe you have an oscilloscope with a memory function. You can pull a shorting pin from the diagnostic connector, hook up the oscilloscope, and using a special sequence found in the FSM pull the codes as a set of pulses.
But most people don't have oscilloscopes.
First thing for you to do is simply crawl around and see if there's any obvious damage to the wires. If you don't find any, then next up is to pull the ABS sensors from each wheel and inspect for metal shavings. Be very careful as the sensors are usually plastic and can break easily.
If there's no obvious wire damage, and all the plugs are nice and tight and clean, and the wheel sensors didn't have any metal shavings then you might just break down and visit the dealer to pull the codes. Or maybe someone here is parting out an LX and will sell you all the wheel sensors cheap and you can swap them in one by one to see if the problem goes away (assuming the ones you bought were good!) Or ask a really good friend with a working LX450 to let you borrow their plugs and swap them in to determine which one is bad, and then go off and only buy the one that is broken.
Personally, I'm going to use this as an excuse to buy another oscilloscope ;)
Thanks to all who replied
Thank you all who replied. I pulled all the ABS sensors. The front ones had quit a bit of metal shavings on them under the grease. I cleaned them off and replaced. This for the most part cleared up the problem, however there was an ever so slight problem still. I then pulled and cleaned the back ABS sensors. After this no more problem.
Thanks again. My wife is happy and I feel better.
Found the problem!!
After the problem came back I re-checked the ABS sensors. While pulling the rear sensor I heard a clink as I pulled it out. I then pulled the rotor off and found one of retention pins holding the rear brake shoe had either broken or somehow fallen out, thus leaving the spring and two washers loose. This was slowly chewing them up causing small metal filing to attach to the magnet creating the sensor and ABS issue. I ordered a parking brake rebuild kit and all is well now.
Thanks again for all the insight and help.
You guys are a wealth of knowledge.
