ABS module reassemble help
Elko, NV
Pulled master cylinder to investigate cause of fluid leak from ABS module. As I pulled MC away from the ABS valve body a small metal pin fell out, and I didn’t get a chance to see where it came from. It looks like there’s only two options, can any help me located the proper placement for this pin? I’ve been searching around for a while now with no luck.
