ABS light
Goodyear, AZ
hello CSC,
I changed my front brake pads on my 94 LC. Afterwards the ABS light has been on.. any help/info on how to reset or turn the light off?
Any recommendations on shops that read obd1 readings in the west valley. Thanks again for your help/inputs.
Try this possibility: Remove your abs sensors out of the hubs and see if there are metal shavings stuck to the end of it ruining the ability to "see". Clean it/them off, reinstall , clear light and see if that fixes it.
Hi Murf, I disconnected both ends of the abs sensors and looked for metal shavings. I didn't see any. pulled the abs fuse on the driver side reinstalled it.. abs light is still on. im not getting a check engine light just abs light. very confusing.
