ABS light on
hey guys,
i have a 93 cruiser and i recently did the front axle seal job/brakes.
i'm not sure if it's related but now my ABS light is on. it SOMETIMES goes away though but usually comes back on and stays on.
prior to doing this job, the ABS light only sometime came on and not as frequently.
i've checked the fluid level and it's fine. anywhere else i can check??? the brakes feel perfectly fine...
thanks for any and all help
hey guys,
My first guess would be an incorrect air gap on the sensor or maybe the plug is loose/not connected.
Pull the sensor out and make sure you clean the seating area and holddown. When you re-install make sure the sensors are pushed firmly back into place and see it thats fixes the problem.
If it was coming on before it may be rust or metal pieces stuck to the (magnetic) sensor tip. Mine did this, it was a rear sensor. One screw holds the rear sensor in.
gotcha, thanks guys i will take out both front ones, clean them and try to seat them on firmly before screwing it back in.
i'll also check the rear ones as well. hopefully these will fix the problem!
i was thinking vacuum leak of some sort and i checked, hearing a slight hiss coming from the engine bay. i gotta find where it is coming from exactly but that may not be related to this ABS light issue.
i haven't checked and cleaned the ABS sensor yet... but i have noticed that at exactly 70 mph the abs light goes off...
it comes on and off usually... so i don't know if that has to do with anything? i found that kind of interesting how it was MPH/speed related...
I just did the Slee 4" lift and now I have an ABS light as well.
I'm thinking I'll check all the connectors and hit them with some cleaner.
