ABS Codes 31 & 32
Annapolis, Maryland
Before I starting doing the drill down in the factory service manual, I am hoping that someone has a quick fix for me.
My '94 80 started to have the common problem of having the ABS activate when coming to slow stop. The light was not on.
Per the advice of many, I took each front sensor out and cleaned them off. The driver's side did have some metal filings on them.
After cleaning them, the ABS light has come on with codes 31 and 32 indicating malfunctioning senors at both front hubs. It is dangerous to drive, as at high speed braking the ABS will function incorrectly and make the truck lurch from one side to the other. I almost wrecked it on the first test drive I made.
Any thoughts?
Ever fix this? I am having same issue
After cleani
Any thoughts?
